-   -   chain boxes (http://forums.pelicanparts.com/911-engine-rebuilding-forum/794761-chain-boxes.html)
jhg41977 02-02-2014 08:10 AM
chain boxes
I am rebuilding the engine in my 993 and the chain boxes show some pitting where the seal to the cover sets. The covers also show similar marks, although more like chipping, where the seal sets into the groove. The rest of the boxes and covers look fine. I washed them initially in a parts washer which has only had econosolve in it. I believed these to be aluminum and econosolve is safe for use on aluminum per the manufacturer. The marks were visible before cleaning, so I do not believe these to be related to cleaning. I used a brass brush in the seal grooves while cleaning.
So, what to do. Do I add a sealant? Can I lightly sand the groove in the cover smooth or at least smoother? Do I do both?
I would love to just replace the boxes but they are not cheap. I have looked on ebay but have not been able to find a complete set.
Jim
bobolsn 02-03-2014 07:07 PM
Jim,
I do not know the answer, but pictures may spark some comments and suggestions. There are very knowledgable people that respond.
Bob
jhg41977 02-04-2014 03:58 AM
I'm on vacation, will return on Saturday night and post pictures on Sunday.
Lapkritis 02-04-2014 05:26 AM
Sounds like a job for JB Weld if you specifically do not want to replace or deal with welding to fill and then machine work.
jhg41977 02-04-2014 05:36 AM
Welding magnesium?
Lapkritis 02-04-2014 05:51 AM
Takes a specific rod and gas. Depending on the work it might be better to replace or use the aforementioned cold epoxy.
https://www.youtube.com/watch?v=tausy8soPzU
More than one way to skin this cat as usual.
