Clutch Frustrations. Help Please
I'm a little uncertain of what to do with the clutch on a 69 911S. The disk is in need of replacement. I had planned on changing disk, pressure plate, throw out bearing, etc. It looks as though the Pressure Plate is over $1000. Ouch. The Disk is no longer available. Any ideas where to get the required parts for this job, and/or any thoughts on re-using the pressure plate??
Also, going to have the flywheel looked at tomorrow. Hopefully it is within tolerance. 11MM minimum, correct? Any advice is appreciated. Dave
If the FW cleans up, no reason not to use it. Pressure plate might be iffy. Check with EBS for disc.
Tell it like it is or don't tell it at all. |
Thanks for the response. EBS has my cylinders now so maybe they can send a disk or point me in the right direction.
