found a silicone type of glue in block? is this stock?
Hi Guys , should there be silicone at these spots?
Thanks Erickhttp://forums.pelicanparts.com/uploa...1392069957.jpg http://forums.pelicanparts.com/uploa...1392069995.jpg |
These casting areas were left unsealed from the factory when a pressure cast aluminum case was first released and then sealant was added after leaks were discovered.
We use Loctite Hysol but JB Weld is very similar. http://forums.pelicanparts.com/uploa...1392071199.jpg |
Thanks for the fast reply
Was this added at the factory, the car is a 89 turbo |
Yup.
Should there be JB weld used inside the case? On another thread I thought others were against it? In case is were to break off and get caught in the oil screen???
Good point Justin
Can you use JB weld on the inside? Thanks |
| All times are GMT -8. The time now is 08:24 PM. |
