Try not, Do or Do not
68 L aluminum case
A few months ago, some on this forum was looking for a 68 L aluminum Case.
I have one if you still need it. # 47 Cheers
Henry Schmidt SUPERTEC PERFORMANCE Ph: 760-728-3062 Email: supertec1@earthlink.net |
Woodland Hills, CA
There is no difference between an L and Normale 68 aluminum case Henry. So why the L designation? Still a hard to find case for 68.
The difference 68L euro 308..... 318..... 68LUS 328.... 338....
Serial number....that's it. These cars are so valuable now that coming up with a close engine number is the next best thing to matching numbers.
Woodland Hills, CA
Targa68
What's the engine number and how much?
308 0047 serial with a 901/01 designation number ( the 901/01 was as error, it is actually 901/06) I have heads, intermediate shaft, cam towers and chain boxes as well. I also have a sand cast case that has a casting mark of 64. VVVVVVVVVVVVV ![]() ![]()
Henry Schmidt SUPERTEC PERFORMANCE Ph: 760-728-3062 Email: supertec1@earthlink.net Last edited by Henry Schmidt; 02-18-2014 at 08:20 AM.. |
Nice case 308..... euro case same int as S engine 901/06
The type # should be 901/06. Do you have a photo of the type # and the build # also please?
The 11/64 date code on engine 901238 is interesting; they cast a lot of engine cases in 1964 by the looks of things.
Keeper of 356, 911, 912 & 914 databases; source for Kardex and CoA-type reports; email for info Researching 356, 911, 912 & 914 Paint codes, Engine #'s and Transmission #'s Addicted since 1975 |
Aluminum Case
I have a '66 911, would it have had an aluminum case? When did Porsche go to the mag case? Currently running a 2.2. Bob Shafer
Like mid 68
Henry Schmidt SUPERTEC PERFORMANCE Ph: 760-728-3062 Email: supertec1@earthlink.net Last edited by Henry Schmidt; 02-18-2014 at 08:21 AM.. |
Yes, absolutely; the change to mag case was in 1968 model year. What VIN & paint code does it have? I can guess the serial range.
