-   -   Distributor Installation. (http://forums.pelicanparts.com/911-engine-rebuilding-forum/796804-distributor-installation.html)
keynsham1 02-15-2014 10:57 AM
I have a 911SC and I am refitting the standard distributor after an engine rebuild. Wayne Dempsey's book shows the distributor fitted with the rotor lining up with a notch on the case, but it is a different distributor to mine as the book rebuilds a 2.7 not a 3.0. Bentleys book for the 911SC shows a picture of the correct distributor and says to align it as shown in a picture, but the arrows in the diagram are missing! I guess a publishing error. I think there is a notch on the casing of my distributor, but it is very small and almost looks like a scratch. Should I install the distributor with the rotor aligned to this mark?
http://forums.pelicanparts.com/uploa...1392490611.jpg
Any pictures would be greatly appreciated.
pete3799 02-15-2014 11:47 AM
Looks like the right notch to me.
Just make sure your at top dead center on the compression stroke.
pors1968 02-15-2014 01:09 PM
That the notch as PETE said compression stroke top dead center.
