Valve cover choices
I need to replace both my upper and lower covers. A hour of surfing the net (many it was two), and I still don't know what I should buy. I'm not going to fork over $300 to get the CNC ones, but what is the smartest choice?
Straight shooter
You'll spend more than $300 for the billet machined which are the best. Roughly $300 for the top pair and $300 for the bottom pair so closer to $600 total. Add gaskets and shipping and you're getting up there... gaskets are then reusable and they won't leak. I really like the Hargett pieces the host sells and use those on my engine after having a local business add milspec black hard anodizing. Smart money in my book for no leaks and a much better, modern gasket design.
“Of the value traps, the most widespread and pernicious is value rigidity. This is an inability to revalue what one sees because of commitment to previous values. In motorcycle maintenance, you MUST rediscover what you do as you go. Rigid values makes this impossible.” ― Robert M. Pirsig, Zen and the Art of Motorcycle Maintenance: An Inquiry Into Values |
Straight shooter
![]() ![]() ![]() ![]() ![]() I had Hargett send the bottoms without ribbing on the outside so I could add heatsinks. ![]() ![]() ![]() ![]()
Straight shooter
Couple more
![]() ![]() ![]() Headers are wrapped. ![]() ![]() ![]() ![]() You may have gathered that I'm one of the few who believes the functional area of the valve covers is an area of the engine that is neglected and vastly under-engineered relative to the rest of the engine design. Playing with sandwich gaskets bonding to surfaces, dripping, warping and cracking covers wasn't a game I wanted to play. YMMV.
Very nice. The heat sinks wouldn't work for me as its going in a 914.
911SC Tinkerer
Those heat sinks are AWESOME!
-'83 911SC Coupe SSIs, Dansk GT3, EFI ITB, Instagram: @ Zinnmetallic_sc |
Puny Bird
Yep, nice bling but none of that will work in a 914, just get turbo covers and mill down the ribs.
The tops are standard issue and you should be able to find a good set in the FS/WTB forum.
'74 Porsche 914, 3.0/6 '72 Porsche 914, 1.7, wife's summer DD '67 Bug, 2600cc T4,'67 Bus, 2.0 T1 Not putting miles on your car is like not having sex with your girlfriend, so she'll be more desirable to her next boyfriend. |
I bought a new set of lowers from Patrick and they are milling them down for a reasonable cost. Still looking for the uppers. What's the real difference between mag and aluminum?
