-   -   WUR serial number (http://forums.pelicanparts.com/911-engine-rebuilding-forum/799034-wur-serial-number.html)
matt2000 02-28-2014 11:17 PM
WUR serial number
Hi,
I have a question regarding the serial number of my Warm Up Regulator.
I can read the 0 438 140 serial number on the WUR, but there are no additional -1 or else next to it...
I need to replace the WUR and would like to do a core exchange, however it seems that I am missing an additional number to identify my WUR correctly...
(car is 911 SC from 1979, but I do not know if the WUR is original).
thks for your help!
Best,
Matt
pete3799 03-01-2014 06:35 AM
US or euro model?
E Sully 03-01-2014 08:10 AM
Found this.
http://forums.pelicanparts.com/uploa...1393690218.jpg
boyt911sc 03-01-2014 01:09 PM
Clean the top side.......
Originally Posted by matt2000 (Post 7937469)
Hi,
thks for your help!
Best,
Matt
Matt,
Clean the top side of the WUR specially around the post. The number is 0-438-140-xxx. The first seven numbers were cast or molded on the body while the last 3 digits were stamped on it. Get a small wire brush or the like and gently clean the area. Either -045 or -069 on the engine if you have the correct WUR.
I could lend you a WUR if you need one and you don't have to buy it unless you want to keep it. Why do you think you need a replacement WUR? Have you tested it? Keep us posted.
Tony
