Curil T @ Cylinder base gaskets working time
Going to install cylinders this weekend. Was planning on having a local independent guy here install heads and towers, maybe next weekend. Can I put Curil T on the cylinder base shims when installing cylinders even though won't be torqued down with heads till next week? Should I just install the shims dry instead?
Thinking about letting local guy here finish up engine. |
Okay to put on now as normal with Curil T. Hold the cylinders in place with a couple spacers under the head holts until your guy shows up. Stays gummy.
Thanks Lap,
Gonna load it up in truck next Sat. |
as far as ive experienced, curil t working time is at least 60 months. ive taken motors apart 5 years later and the curil was still tacky and flexible.
yup, and blue hylomar works just as well and never dries.
| All times are GMT -8. The time now is 02:24 AM. |
