-   -   How do you guys secure the small vacuum hoses (http://forums.pelicanparts.com/911-engine-rebuilding-forum/800362-how-do-you-guys-secure-small-vacuum-hoses.html)
ertech 03-09-2014 08:08 AM
Hi guys
How do you guys secure the small vacuum hoses? With small tyewraps?
cgarr 03-09-2014 05:22 PM
Something like this:
http://img.tapatalk.com/d/14/03/10/u4ysy5yh.jpg
DSPTurtle 03-09-2014 06:27 PM
Tie wraps work too.
HawgRyder 03-09-2014 07:02 PM
Heat shrink tubing.
Bob
Walt Fricke 03-09-2014 09:00 PM
Oetiker clamps are pretty cool. Porsche used them on pressurized lines. I use a tile nipper to squeeze them - much less expensive (and I had one already) than the prescribed tool.
However, I think I generally don't use anything on most of my vacuum hoses. Like the two on the SC distributor - they don't need any clamping. After all, the have a vacuum inside which is trying to squeeze (a little bit at the end anyway) the tube to the tube over which it is slipped.
However, where a line may be subject to pulling forces, a clamp may be in order. Or on the brake booster lines.
Hadn't thought of heat shrink - interesting.
Ronnie's.930 03-09-2014 09:12 PM
I've use tiny tie wraps on vacuum hoses on motorcycles and cars for over 20 years and have never had a problem doing so (like Turtle said, they work fine).
proffighter 03-14-2014 04:26 AM
Oetiker SS with inner sleeve (avoids damage at clamping area)
Easy to fit, durable, short said best for an application like that (and lightweight:D )
http://forums.pelicanparts.com/uploa...1394796370.jpg
BTW @ Walt:
I used a crusher where I rounded the cutting edges...
proffighter 03-14-2014 04:34 AM
... And I prefer one like this rather than a sideways cutter, easier to find correct clamping force and no damage to the clamp due parallel clamping
http://forums.pelicanparts.com/uploa...1394796847.jpg
aquazulu2 03-14-2014 09:23 AM
Originally Posted by HawgRyder (Post 7953229)
Heat shrink tubing.
Bob
Neat!.. Never thought of that either.
Walt Fricke 03-14-2014 11:06 PM
Roland - that looks like what I use.
