-   -   how to determine deck height of a cylinder (http://forums.pelicanparts.com/911-engine-rebuilding-forum/801733-how-determine-deck-height-cylinder.html)
scootergt3 03-18-2014 08:58 AM
I'm in need on one new cylinder for my 2.7. to make sure I find the right cylinder, I wanted to know how you measure deck height. ( the cylinder I plan to purchase has a deck height of 5) my current cylinders have no marking for height. can anyone provide me for the correct measurement locations/?
jhg41977 03-18-2014 04:24 PM
Have you cleaned your cylinders and looked very carefully? Mine was stamped pretty light
tom1394racing 03-18-2014 04:54 PM
You are confusing deck ht with cylinder ht group.
Deck ht is the distance from the piston edge to the cylinder sealing surface and depends on a variety of build dimensions.
Cylinder ht is the distance from case spigot mating surface to the head mating surface on the cylinder.
I will send some pics to your email tomorrow that will clear things up.
