Restarting 3.0 rebuild what to do????
I am out of outage season and I can start on my rebuild again. The engine has been sitting all winter in my garage south of Detroit. What do I have to do when I start reassembly again? The case is together and that is about it. I have to install one rod/piston that I had to take out to have the piston pin sized and go on from there. Is there any thing I have to worry about with regard to lubrication? Thanks.
As long as you used assembly lube initially, I don't see a problem.
Thank you
Yes I did.
| All times are GMT -8. The time now is 10:46 AM. |
