kanna's Avatar
Rocker arm bushing source
Anyone have a source for 911 rocker arm bushings( bearings)?
Old 10-25-2007, 10:39 AM
abit off center
cgarr's Avatar
I was looking for the same, this is what I found and posted on Gruppe B
http://www.gruppeb.org/forum/viewtopic.php?t=4629
______________________
Craig
G2Performance
Old 10-25-2007, 12:13 PM
kanna's Avatar
Ordered some the other day. Since we have an account with Motion Industries, they cost less than a buck each. I'll post my findings on them when they arrive. Also spoke with Walt at Competition Engineering and he confirmed that there are no sources for the original Porsche bushings.....but Porsche will sell you new rockers for $100 each! Doooh!
Old 10-27-2007, 01:56 PM
Jeff Alton's Avatar
Porsche must not like you, Pelican will sell you a new rocker arm for 62.75.....
Cheers
www.turn3autosport.com
Old 10-27-2007, 09:29 PM
I got bushing material from a bearing house and then we cut the OD for the press fit and ID to be ready for the honing of the fit to the rocker shaft... I forget just now the exact bronze part number. I think bronze basically comes in 3 types.. soft, med. and very hard.. We used the med.
Don't forget to drill and debur the oil holes
Old 10-30-2007, 07:44 AM
kanna's Avatar
bronze bushing material is waaaaayyyyy too soft. lots of pressure exerted on rocker bushings. Got the Buntings today and just finished doing a set of rockers. They are perfect.
Old 10-30-2007, 04:15 PM
would be interesting to see if the "experts" weigh in on this.. re. "building" your own bushings from various materials... until now haven't heard of Buntings. The machine shop I used has been doing 911 heads (that's about all he does) for decades and I used what he recommended. I would not be surprised if the bronze was not the best choice.... how did you arrive at using Buntings?
Old 10-31-2007, 07:04 AM
I read the Buntings website info. I remember now the bushings I got were 660. There is a bunch of interesting info... re. press fit, running clearance, groove types, graphiting.. Not sure if the clearance recommendations follow the Porsche numbers... and I don't remember what I reemed to but when I was done I could only feel a very slight play... continued conversations re. press fit, clearance, grooves etc. would be interesting.
Old 10-31-2007, 07:36 AM
Description: 18 MM ID, 20 MM OD, 25 MM LENGTH, TEFLON LINED, SLEEVE BUSHING
MFG Part #: M1825BU BRG
Manufacturer: BUNTING BEARINGS
this is from the cgarr above... sounds pretty good.. I guess these get reemed to size or is the tolerance of the running clearance going to fall within what is needed when using "buffed" rocker shafts. I think my rocker shafts were buffed on some sort of centerless machine... not sure how much is/was taken off but it is not much
Old 10-31-2007, 09:23 AM
abit off center
cgarr's Avatar
This was a perfect press fit, ran a ball hone thru the bushing for a perfect fit. Remember to keep the split side to the top and it always helps to use a wood dowel in the rocker when drilling the oil holes.
[IMG][/IMG]
Craig
G2Performance
Old 10-31-2007, 07:06 PM
good idea re. wood dowel... I can't remember what we did on that. I did go in and "round" out where the oil hole is to give some room for oil to accumulate
you say split to the top...
are you refering to the original style where there is a complete split in the bushing? The bushings I made of 660 were solid all the way around..
Old 10-31-2007, 07:23 PM
fancytown
Originally Posted by hcoles View Post
...you say split to the top...
Thin bushings of the sort are typically rolled bushings, with the split. If you machined a slighjtly heavier piece of cast bronze bushing, that's fine too. It's what most of the shops do, if you were to send them out. The difference will only be the process used to make the bushing.
all cars sold.
Old 11-03-2007, 06:46 PM
oh ok, I didn't know the rolled type were available in any way... yes I machined pieces of cast bronze 660. I'm pretty sure there is a more ultimate way to do it than I did.. we'll see how long they last. I like the sound of the teflon lined or other such exotica and I guess if grooves are put in in the proper type and pattern that could help also. So far so good with what I did. If you have a shop do this for you.... remember to check the tolerance. I guess at this point we now all know to check what the shops do... no dig intended to the real good shops.
Old 11-03-2007, 08:00 PM
abit off center
cgarr's Avatar
Trying to simulate these new bushings installed on an engine. Adding some load, some heat while spinning in the lathe and very little oil to see how they hold up. This may be one of those things I leave on all night and check it in the morning. Should have a test engine for these soon. So far after several hours no change in the bushing.
Craig
G2Performance
Old 11-04-2007, 07:09 PM
Craig,
very admirable but not sure if this matches the real situation enough to prove too much...
what bushings are on the lathe seup? 660 bronze?
Old 11-05-2007, 05:22 AM
abit off center
cgarr's Avatar
I am testing the TEFLON LINED, SLEEVE BUSHING, I realize there is no shock factor with this type of testing, but I had to try something before they go in the engine. I was concerned with the teflon not holding up. The teflon is a very thin lining over the bronze, even if the teflon was removed the clearance is not excessive.
Craig
G2Performance
Old 11-05-2007, 05:54 AM
abit off center
cgarr's Avatar
For what its worth, I setup a stock rocker (bronze bushing) in the lathe and could only run it for 5 minutes at which time it was too hot to handle, the teflon lined bushing is still running and hardly warm.. But the true test will be in the engine.
Craig
G2Performance
Old 11-05-2007, 03:01 PM
well that sounds pretty good... the teflon film seems to be hanging in there for whatever reasons.. certainly worth a try to put in an engine... I applaud the experimental effort you put in. I find in almost all experiments even if they are not perfect.. are helpful
Old 11-05-2007, 03:34 PM
abit off center
cgarr's Avatar
I needed the worst case test and something to compare to so this is what I did next to try and make both fail.
No oil test. Stock bushing after brake clean, ran 7 min then started to seize up, this baby was hot, bushing was scared badly, shaft did not look good.
Next was the teflon lined after brake clean, Well after 20 min and still not hot I added some Mapp Gas heat up to 500 degrees to help get it to fail, but it didn't, its still running and cooled back down and this is with out any oil.
But again, the only real test that counts is time in the engine.
Craig
G2Performance
Old 11-05-2007, 03:50 PM
abit off center
cgarr's Avatar
Just found this regarding these bushings and the material used: Read towards the bottom:
Little Resistance With KS Bearings Permaglide(R)
DETROIT, April 12 /PRNewswire/ -- Kolbenschmidt Pierburg's KS Bearings
division is expanding the use of its slippery Permaglide(R) friction-reducing
material to produce components that take up less space, weigh less and offer
improved performance for North American automotive products.
After succeeding in its quest to find an environmentally friendly material
to replace the lead found in many automotive lubricants, KS Bearings now uses
Permaglide(R) on components such as transmission gear-shift-lever guides, door
hinges and shock absorbers.
"This really is a break-through material that can be incorporated into
hundreds of different automotive applications," notes Mike Adrian, KS Bearings
vice president of North American sales. "Permaglide(R) offers advantages not
only in cost, but in weight and performance as well. Its use also will have a
positive environmental impact."
The patented Permaglide(R) process, developed and owned by Kolbenschmidt
Pierburg, incorporates a 1-millimeter to 1.5-millimeter sandwich of PTFE
(polytetrafluoroethylene, commonly known as Teflon(R)), zinc sulfide and
bronze bonded to a steel backing.
Components with an extremely slippery P1 Permaglide(R) surface can handle
higher loads, speeds and temperatures. P1 Permaglide(R) can be manufactured
to require no lubrication, allowing manufacturers to eliminate many lead-
containing lubricants such as the grease used on conventional front-wheel
drive shafts. Permaglide(R) components satisfy the ELV (end-of-vehicle-life)
directives already in place in Europe that require vehicles to be 85 percent
recyclable by 2006.
KS Bearings also produces a machinable version of the material, P2
Permaglide(R), for components that may require lubricants because of load,
temperature or speed. The frictional characteristics of Permaglide(R)
materials can be custom-tailored to a specific application. "If it's too
slippery -- for example, on a door hinge -- we can add more resistance to give
a better feel," Adrian says.
Permaglide(R) is finding its way into areas that previously were
considered unsuitable for this type of application -- inside an internal
combustion engine, for example. "We're currently testing Permaglide(R) on the
rocker arms and camshaft of a high-performance V-8 engine for a major
manufacturer," Adrian says. Permaglide(R) reduces parasitic friction losses
on those components, improving the overall efficiency of the engine.
"We've also have had strong customer interest in our door hinges and shock
absorbers," he says, "and we have the manufacturing capability to meet our
customers' needs for multiple shapes and sizes and any geometry."
KS Bearings engineers can redesign components to take up less space with
lower weight and improved performance. The division uses Permaglide(R) on 100
percent of the door hinges, pedal systems and windshield-wiper components it
manufactures for a major German automaker.
Typical areas of application for Permaglide(R) components include:
Auxiliary systems -- common-rail pump, brake and fuel systems, engine belt
tensioners and starters.
Powertrains -- contoured switching guides and dual-mass flywheels.
Suspension components -- shock absorbers, struts, steering systems and
brake systems.
Chassis -- hinges on doors, hoods, trunks and tailgates, windshield
wipers, body systems, seat adjustment gear, safety belt pretensioners and
pedal systems.
Permaglide(R) also is used in many non-automotive commercial and
industrial applications. Kolbenschmidt Pierburg AG owns worldwide rights to
the material, and the company markets the process to non-automotive customers
through a license with INA-Schaeffler KG of Germany.
KS Bearings, a key manufacturer of engine bearings, journal bearings,
bushings, flanged bushings and thrust washers for the global auto industry, is
a division of Kolbenschmidt Pierburg, a leading supplier of bearings, pistons,
automotive oil and water pumps, throttle bodies, secondary air systems and
exhaust flaps, as well as electric exhaust-gas-recirculation systems and
aluminum engine blocks. Kolbenschmidt Pierburg has North American production
plants in Fountain Inn, S.C.; Greensburg, Ind.; Fort Wayne, Ind.; Marinette,
Wis., and Leamington, Ontario, and a North American sales office in
Southfield, Mich.
Kolbenschmidt Pierburg AG is a subsidiary of Rheinmetall AG. The company
has approximately 11,400 employees at its five automotive divisions. Global
sales for its Aluminum Technology, Pierburg, KS Pistons, KS Plain Bearings and
Motor Service divisions totaled nearly $2.4 billion in 2004. Additional
information is available on the Internet at
Craig
G2Performance
Old 12-27-2007, 06:59 AM
