G50911's Avatar
Help with knock noise
I noticed that on first start ups there's this knock noise I hear. It goes away after a few minutes or as the engine gets warm.
I'm very hesitant to drive it now cause I don't want to cause any more damage if this is in fact rod knock or what ever it is.
Can anyone help ID this noise?
https://www.youtube.com/watch?v=r5GHT7oTeQg
1967 911 (Azzuro Thetys) - #308439
1971 911 (PTS Black) - Built 3.6 Sleeper
1989 911 (Grand Prix White) - Cabriolet Bone Stock
Old 03-24-2014, 01:05 PM
Len 911's Avatar
Not sure maybe a Gas knock. How old is the gas? What did you do to the car last, did you mess with the engine or did this just start happining.
Old 03-24-2014, 01:31 PM
FPB111's Avatar
Have you checked the valve clearances? Timing chain is usually louder at idle, rod usually sounds deeper, piston slap? Get your stethoscope out and see if you can pinpoint it.
2013 991.1 Carrera S Cab
2004 996 Turbo CAB X50 sold
2003 996 cab 6 speed Sold
1972 RS 3.2 twin plug short stroke crank fire, roll bar, sold
DE instructor since 1985
Old 03-24-2014, 01:38 PM
G50911's Avatar
gas is new. tank was cleaned and flushed before i filled it. i've been trying to get my carbs dialed in and i noticed it when i started it in the mornings it would be pretty loud. that video is not at operating temp but is not at a cold start either.
what i noticed is the #6 cylinder's plug is slightly wet and according to my carb float tool it's the weakest of the 6.
Old 03-24-2014, 01:41 PM
abit off center
cgarr's Avatar
Sounds like piston slap and it will go away as the pistons warm up...
______________________
Craig
G2Performance
Old 03-24-2014, 01:50 PM
911 2.2 T targa
You could compare to my knock movie in fourth post
Hopefully your sound is different. In my case cylinder 4 seized, possibly caused by a bore wash
Old 03-24-2014, 02:05 PM
Reiver
Reiver's Avatar
If you have forged pistons (Nikasils) you often hear a knock/slap when cold. Normal. Same thing happens in SB Chevy's too with FP's.
Rod knock does not go away when warmed up.
Old 03-24-2014, 02:07 PM
G50911's Avatar
not sure if the pistons in there are forged. i took it to my wrench and will know a little more later or early tomorrow.
as an aside, anyone know if oil weight has anything to do with this? i put 20/50 (after a complete flush) in it and not sure if thats the same weight the PO used.
Old 03-24-2014, 04:46 PM
If you are playing with the carbs you can make it knock if you get a cylinder too lean. That won't normally go away as the motor warms.
Old 03-24-2014, 07:12 PM
Doesn't sound quite like a rod knock, but could be a piston pin. If I remember, though, the noise of a loose piston pin changes volume aa the engine is accelerated and decelerated. The other suggestions about piston slap and a loose t chain tensioner are also very viable. Stethoscope should help.
Old 03-24-2014, 09:35 PM
G50911's Avatar
valves were too tight and stuck open. compression was at 70 psi and after the valve adjustment it came back to 150 psi.
whew!!
Old 03-25-2014, 07:31 PM
