hydraulic rocker questions
I installed new hydraulic rockers during the rebuild. When the cam is rotated so that the valves would be closed, the rocker still has slight pressure on it when installing. The valve does not move so I am assuming this is just the hydraulic lifter keeping constant light pressure as they are supposed to. Am I correct? Valves were done and I was told they were length corrected.
