-   -   Who makes the best performance valve springs & retainers (http://forums.pelicanparts.com/911-engine-rebuilding-forum/803669-who-makes-best-performance-valve-springs-retainers.html)
slow car 03-29-2014 05:22 PM
Hi there seams to be many claims about performance valve springs and Titanium retainers.
I am needing a set for a race engine 3.4 lt .
Who can advise as to what has proven the best ?
AlfonsoR 03-29-2014 07:32 PM
I think you may want to ask who can recommend brand of springs for the cam you are running and ask who makes the lightest retainers.
Most folks on here will not be able to give a good answer since we are mostly end-users. You really need to talk to pro builders that have built and used different combinations. Even then, everyone has their favorites.
slow car 03-29-2014 09:26 PM
Thanks James
911pcars 03-30-2014 01:28 PM
Not sure the lightest retainers (weight savings = X grams), ti or otherwise, inspire the most confidence in a high-revving race engine with significant spring loads. You might save more significant weight by using lighter valves. The lightest and strongest are probably out there, but I'd research thoroughly. Dropped valves and random engine debris are to be avoided if at all possible. For racing applications, routine inspection, maintenance and replacement are to be expected.
Sherwood
lvporschepilot 04-01-2014 11:37 AM
Eibach make an excellent set of springs. They are about 100lbs at the seat and 260lbs at .500 lift. Not so sure about retainers....
Daniel Cooper 04-02-2014 02:17 PM
Jerry Woods
very happy with their valve springs and retainers
mamut 04-19-2014 01:12 PM
Shrick., Stef.
porschetub 04-19-2014 09:49 PM
His name appears time and time again so its a X2 on that
BURN-BROS 04-20-2014 09:45 AM
Dougherty offers springs and Ti retainers.
Valvetrain stability to 8700 rpm with a DC 90 cam
110 lbs seat and about 285-290 depending on lift
