-   -   Doing "twin plug" in stages: does it make sense? (http://forums.pelicanparts.com/911-engine-rebuilding-forum/804337-doing-twin-plug-stages-does-make-sense.html)
Henry Schmidt 04-04-2014 11:38 AM
Originally Posted by MBruns (Post 7997061)
Speaking of your studs Henry can you send me a set please ? 3.0 based 911
Thanks, Mike Bruns
Sorry for the Hijack
Give me a call.
JohnJL 04-04-2014 12:59 PM
there are smarter guys than me here so id retract what i said and listen to Henry, Steve or another expert here.
Schmierung 04-07-2014 09:42 AM
I was in your situation about 25 years ago with my street/track car. I had little funds and did not yet have enough dough for a big car/truck and trailer. In the midst of a refresh of my screaming 2.45, We found a set of pistons very cheap, but they were very high compression.
So Hank did twin plug machining while the heads were apart and I assembled everything using many (can't remember number, but many) copper cylinder shims to get a street-able Ratio. Ran that happily for a season, then dropped the engine, but still under car. Spent a day removing chains and loosening head nuts and such to permit backing off of the cylinder about 15mm. Just enough to get a cutter in there to remove the shims and then re assemble. Found a good deal on a used electromotive and was ecstatic about the project.
