-   -   Fresh rebuild will not start (http://forums.pelicanparts.com/911-engine-rebuilding-forum/804385-fresh-rebuild-will-not-start.html)
jhg41977 04-02-2014 07:10 PM
Video here 993 won't start - YouTube
With the dme pulled, the motor spins freely and builds solid oil pressure. With the due installed, see video. The motor spins a few times, then pauses, spins a few times and pauses.
There is pressure in the fuel rail. The exhaust 'blows' Ive had a long day and it's cold out so we called it a night. Any suggestions?
rennworks 04-02-2014 07:45 PM
sounds like ignition is out of time. Put it on tdc#1 and make sure both pointers on the distributors are correct.
warren
jhg41977 04-02-2014 07:47 PM
So incorrect timing will not always pop or backfire?
rennworks 04-02-2014 07:49 PM
thats right
jhg41977 04-02-2014 07:52 PM
Thanks Warren, I'll check that in the morning.
Jim
adeak1 04-03-2014 04:59 PM
Did you do the timing of the Cam's
TDC for #1 should have both rockers moving, then set distributor for the timing mark. I am doing a 964 a did the timing of the cams and it started on the third try. good luck
Andrew
jhg41977 04-03-2014 06:45 PM
All set now. Distributor was out of the by about 60 degrees.
Just started it up, run smooth. Thanks for the help!
