-   -   Which carbs 69? (http://forums.pelicanparts.com/911-engine-rebuilding-forum/804915-carbs-69-a.html)
jcc911 04-06-2014 06:26 AM
Which carbs 69?
Trying to determine which factory carbs came on a 69 t engine? Thanks.
Mo_Gearhead 04-06-2014 06:36 AM
Weber type 401DT3C
jcc911 04-06-2014 06:40 AM
Awesome thanks for the info. How easily are they to come by?
Mo_Gearhead 04-06-2014 06:52 AM
How fat is your wallet?
I'm not certain on the availability. If you find originals, they are usually well-worn; throttle shafts, bushings, etc.
Some just look at replacing them with newer PMO's. Good luck.
jcc911 04-06-2014 07:17 AM
Ok thanks for the info.
