b930's Avatar
head damage during shipping, repairable?
Hi guys,
I recently bought some second hand 3.2 heads from an ebay seller who shipped them internationally, unfortunately he stacked the heads with three on top of the protruding studs of three heads in the bottom of the box.
The heads on top sustained damage from the studs impacting the combustion chamber and sealing areas as per the pics. I dont want to skim them down and change deck height, and was wondering if anyone knows if these can be spot weld repaired and skimmed back to original height?
1988 930: 3.5L 100mm LN slipins, LN FFA rods, Supertec studs, GT3582R with T4 1.07A/R twin scroll housing, RarlyL8 equal length divided headers, dual Tial MVS 38mm WG's, Carrera 3.2 heads with 993 big valves. 964 Cams, full bay IC, KEP st1 clutch. PE3 sequential ECU with 750cc EV14 injectors, CoP twin plugs, J&S Safegaurd, Aquamist HSF3 water inj. Wavetrac LSD.
Old 07-30-2014, 05:12 PM
Paypal or shipping insured? Seems like alot of work for a set of 3.2 heads etc.
Old 07-30-2014, 05:16 PM
I hate these unsensitive idiots.
I once got a set of original Solex cams in a box without any protection. one was broken apart and that one damadged the other one unrepairable.
6 weeks diarhoea for such idiots.
Do good and weld them, thats possible.
But: Sometimes such damages look worse than they are. maybe a slight surfacing odes the job.
Old 07-30-2014, 05:53 PM
abit off center
cgarr's Avatar
It looks pretty deep but .25mm might clean them up that's the factory limit but you can go a bit more. This is a fear when heads are sent to me, always stress to protect the sealing surfaces, I have received some like that, I know that doesn't help.
______________________
Craig
G2Performance
Old 07-30-2014, 07:32 PM
b930's Avatar
Thanks, its definately deeper than .25mm so I think I may have to get my machine shop to evaluate and see if we can spot weld then clean up. This guy was a major parts dealer in Germany, really frigging frustrates me that they can't even pack properly!
Old 07-30-2014, 10:21 PM
banalytic
panama911's Avatar
What about shipping them back home and getting your money back?
What does the seller say about it?
Old 07-31-2014, 08:41 AM
I agree. They REALLY screwed up on the packing. I'd insist they pay the return freight and return the full purchase price, including the shipping. If they refuse to do that, out them. Those heads aren't gonna get returned back to stock specs without spending a ton of money.
The Cap'n
Old 07-31-2014, 11:09 AM
Straight shooter
Lapkritis's Avatar
Not acceptable... welding is always an option but what I would consider a last resort. I would insist on seller owning the pain of fix not you.
“Of the value traps, the most widespread and pernicious is value rigidity. This is an inability to revalue what one sees because of commitment to previous values. In motorcycle maintenance, you MUST rediscover what you do as you go. Rigid values makes this impossible.”
― Robert M. Pirsig, Zen and the Art of Motorcycle Maintenance: An Inquiry Into Values
Old 07-31-2014, 11:13 AM
3 restos WIP = psycho
kenikh's Avatar
The stupidity I have seen regarding packaging when I buy stuff on Pelican always seems to find new lows, every year.
Last set of cams I bought came in a flat rate box, no padding, with a cam end half out of the box. Not just idiotic: IT'S LAZY.
- 1969 911S
- 1980 911SC Targa
- 1979 930
Old 07-31-2014, 02:18 PM
b930's Avatar
Just back from my machine shop, they said the same. It will cost a lot of money and they can't gaurantee the integrity of the weld on the actual cylinder sealing surface as they have doubt's about the composition of the aluminimum and the actual spot weld process etc. My mate is a PhD metallurgist so I'll get him to decipher what I was told......
I will try work with the seller as I think they are reasonable people. If not, then I guess I got screwed.
Cheers.
Old 07-31-2014, 10:19 PM
b930's Avatar
some pics of the actual box......what where they thinking?
More damage....
Old 07-31-2014, 10:25 PM
Straight shooter
Lapkritis's Avatar
If they are a breaker then they have plenty of rubber fuel line to chunk up and slide over the studs...a board of wood between layers in the box is nearly free too.
Old 08-01-2014, 04:57 AM
