-   -   Backup light switch pin (homemade) (http://forums.pelicanparts.com/911-engine-rebuilding-forum/806326-backup-light-switch-pin-homemade.html)
SchnellSchweitz 04-14-2014 07:55 PM
OK... as many of you know, the backup light switch pin is no longer available from Pelican. When I performed my transmission rebuild a few years ago, I lost my pin and followed the directions provided in the link below.
This method worked like a charm until a few weeks ago when my backup switch kept shorting out my turn signal fuse. Anybody else have this issue?
Perhaps I got the pin too long??? I believe I made it the extra 7mm as described.:rolleyes:
Just curious if anybody found a solution.
Thanks in advance.
http://forums.pelicanparts.com/porsche-911-technical-forum/422046-reverse-light-switch-woes.html
SchnellSchweitz 04-20-2014 10:04 AM
Just a quick update on my backup light switch. The old one is shown below. You can see the damage to the switch. The button surface (inside hole) is actually worn into a groove.
My hunch is the groove became too deep and the pin wouldn't actually push the button far enough to reach the contacts or the switch was damaged by a pin that was too long. New switch works great. I used an extra washer to give it a little extra space. SmileWavy
http://forums.pelicanparts.com/uploa...1398013339.jpg
