Check for loose bolts on the exhaust manifold. An exhaust leak can sound just like a rod knock (See Red Coupe above). Ask me how I know.
Bob B |
OK, how do you know? It is a good suggestion. I have already checked them. The head studs were pulling out when I bought this car and I know that sound and it does sound like a knock. My experience with that sound is that it got louder and louder as time went on. This sound stays the same.
Thanks' Bubba |
I have had head-studs broken on a previous 75 911 and I can tell you that it does not sound like a "knock", more like a "popping" sound. And it's more notable/louder when the engine is cold.
Not sure what your induction system is, but I had a knock like sound on #3 that turned out to be a loose intake gasket on the CIS runner at the head - massive vacuum leak.
Pulled it, resurfaced the suspect CIS runner flange, installed new intake gasket....no more knock. |
Any chance the sound goes away when the clutch is pushed in?
Todd |
The sound doesn't go away when the clutch is depressed or when I put the car under load.
I will have a chance to have a pro Porsche mechanic listen to the car next week. I will report back with his diagnosis. Thanks to everyone for their interest. Bubba |
You could check the video in post 4 in my earlier topic http://forums.pelicanparts.com/911-engine-rebuilding-forum/690671-ticking-noise-after-rebuild-70s-911t.html
Hopefully for you it does not sound familiar else I would just start tearing down the engine. |
If it does it at idle, one thing you could do is jack the car up and feel each cylinder for a vibration/knock.
Depending how tough your fingers are you may feel it direct, or else with a small metal bar touching each cylinder. If it is internal and something like a piston hitting head, you must be able to feel it. In which case it would justify tearing the engine down. Alan |
| All times are GMT -8. The time now is 12:24 PM. |
