Valve train noise after rebuilt
Hi guys did a full rebuilt on my 930
Got around 100 mi on the built My engine has a lot of valve train noise as I accelerate , kind of sounds like pinging/ valve noise Can the valve go out of adjustment after 100 mi? What else can this be ? Oil pressure good and lots of power Thanks Erick |
Are you sure it is valve noise? Any chance your timing is too advanced?
Seems like a epidemic of loose broken studs. studs
Did you replace them? (studs) |
Yes 700 worth of them
Just finished readjusting the valves has 2 a little lose Hope it is this Than I will recheck timming Thanks |
| All times are GMT -8. The time now is 02:59 AM. |
