-   -   Engine-Transmission stud 99906103402 (http://forums.pelicanparts.com/911-engine-rebuilding-forum/815811-engine-transmission-stud-99906103402-a.html)
rodoredas 06-12-2014 04:50 AM
hi guys, this part is NLA and I can't find any anywhere, it's the M10 x 67 stud for transmission mount to engine listed in the '83 Katalog, part number 99906103402, any suggestions for alternatives?
cheers
Shane
Walt Fricke 06-12-2014 11:09 PM
Well, I went to my local Porsche junkyard, as I needed all of these studs. Didn't find enough, but got one which was longer. As long as you use a nut, and it isn't too much longer, it should work. Of course, if you don't have such a junkyard about five miles from where you live, you need plan B.
Maryland Metric and other fastener sellers ought to have what you want or something suitable.
As I recall,at least one of these cannot be fastened by a bolt, because the structure of the transmission will prevent inserting it. But it should be possible for the two others. And the one through the starter is a bolt anyway.
rodoredas 06-13-2014 02:45 AM
Thanks Walt,
I found a new set at Patrick Motor Sport, their part number reference is PART # PKG 915 930 G50 SBH ECS, Brian the guy I was emailing was very helpful.
cheers
Shane
