911E carbs and timing
i think the E came with injection? If webers are installed ,triples. should timing be altered? or do I stay with stock setting?
I've done this before. Keep timing stock. I put 32's (venturies) in for track use, 30's for the street.
You have to rejet. I used a bursch exhaust. The car was a lot of fun. |
Thanks Matt, Hey when i rebuild my Webers is there a base adjustment for the air screws under the mixture screws? The ones with the locknuts.
Mixture screws are two turns and air screws are one eights of a turn open.
| All times are GMT -8. The time now is 11:36 PM. |
