-   -   Rev limit on a Carrera 3.2 (3.4) with ARP rod bolts? (http://forums.pelicanparts.com/911-engine-rebuilding-forum/817198-rev-limit-carrera-3-2-3-4-arp-rod-bolts.html)
Tippy 06-20-2014 07:48 PM
What would be an acceptable rev limit for my 3.4 with ARP rod bolts?
It has stock rods, ARP rod bolts, stock valvetrain for a C3.2, and 3.4 Max Moritz flat top pistons.
I have a ginormous turbo now (Borg Warner S366) and this thing wants to rev to the sky.
I'm already turning it to 6500 now and before with the stock rod bolts, I "money-shifted" to well over 8000 RPM without failure.
TIA :)
Steve@Rennsport 06-20-2014 10:27 PM
I will tell you that if you persist in running past 7400 RPM in its current configuration, your wallet is going to undergo a severe shrinking. :) :)
You didn't say anything about the cams you run so I cannot offer you constructive input, however I would not rev your engine past 7K without better rods and a whole host of oiling modifications to the case, crank & bearings as well as 930 oil pump (or better).
Stock 3.2 cams are ALL done by 6400 RPM so thats as far as you should go unless you make a lot of changes.
Tippy 06-21-2014 07:05 AM
Hello Sir Steve SmileWavy, it has stock 3.2 cams. So 7K you think is safe? Was thinking of 6750.
This turbo easily makes up for the 3.2's shortcomings. :D 6500 now comes very easily. :eek:
BURN-BROS 06-21-2014 09:19 AM
Stay under 7000 rpm. Your reciprocating weights are pretty heavy and will put stress on the rod bearings.
Tippy 06-21-2014 10:14 AM
Ok, thanks!
Steve@Rennsport 06-21-2014 10:17 AM
7K is way past the power curves on that engine so anything beyond 6750 represents abuse. :)
Limit it to 6750 and you'll maintain durability.
Tippy 06-21-2014 10:47 AM
Ok. I think I'll keep the 6500 programmed in my MegaSquirt because I saw 66XX in my datalogs in 1st and don't want to risk damage.
Thanks again!
safe 06-21-2014 12:07 PM
I run mine to 6800 with stock internals, been doing that for 5-6 years now. I have a "soft" limit at 6800 so I know when to step off the gas and a hard limit at 7000 that I might have touched one or twice.
Tippy 06-21-2014 12:14 PM
Yeah, I like the soft as it warns you to let off and probably helps to not overshoot the hard limit.
Thanks for input!
