-   -   Can I install the intra cylinder sheet metal after cam towers installed?? (http://forums.pelicanparts.com/911-engine-rebuilding-forum/817272-can-i-install-intra-cylinder-sheet-metal-after-cam-towers-installed.html)
Speed Buggy 06-21-2014 12:24 PM
I need to sandblast and paint the cooling tin. Can I continue with the head and cam tower install and put the tin on afterward? Will it slide in?? Thanks.http://forums.pelicanparts.com/uploa...1403378607.jpg
Heinz911 06-21-2014 01:40 PM
No, you will need to wait
Before you install the camtowers you need to put in the oil return pipes. The pipes will be blocking the tin that needs to go in from the bottom side.
Speed Buggy 06-21-2014 02:27 PM
Not what I wanted to hear, but thank you for the heads up. Have to go blast and paint cooling tin...drats.
boyt911sc 06-21-2014 04:49 PM
Not unless you are.........
If you are using the one-piece oil return tubes (OEM), you have to wait. However, if you are using the collapsible two-piece tubes, you could proceed with the heads and cam towers installation.
Tony
Henry Schmidt 06-21-2014 08:13 PM
There is a third option. Supertec 906 style cooling tin can be installed after the oil return tubes are in place.
At this point there is now great reason to use them but if a mistake happens, they are the remedy.
http://forums.pelicanparts.com/uploa...1403406655.jpg
http://forums.pelicanparts.com/uploa...1403406727.jpg
http://forums.pelicanparts.com/uploa...1403406799.jpg
Speed Buggy 06-22-2014 09:36 AM
Thank you, all. I blasted mine this morning and a getting ready to paint. Two day delay. Hmmmm.
