-   -   Twin Plug 3.2L spark plug wire set (http://forums.pelicanparts.com/911-engine-rebuilding-forum/818415-twin-plug-3-2l-spark-plug-wire-set.html)
pmajka 06-29-2014 07:18 AM
will a 964 or 993 twin spark plug wire set fit my Twin plugged 3.2?
My Clewitt's leaked water in from day 1. need replacement.
pmajka 09-03-2014 07:34 AM
964 wires DO fit a twin plugged 3.2 motor. It now runs when wet (rain) and the pedal on the right of the brake pedal is magical when pressed to the floor.
fred cook 09-03-2014 05:33 PM
Twin plug wires......
I have a set of the Clewett twin plug wires on my SC engine. So far (10 months) I haven't had any problems with them. Maybe mine is working better is because I used the XDi system and mounted the coils on the small shelf in front of the engine, probably the driest place in the engine compartment.
Andrea Bichael 09-16-2014 05:47 AM
Spark Plug replacement is very much necessary to solve the starting issues of a car. For an adjustment one can use 964 or 993 twin spark plug wire set in Twin plugged 3.2 and it will be good as well.
