964 Cams in a 3.0
Are 964 cams in a 3.0 plug and play or is there notching pistons, changing valve springs etc to be able to use them?
Tom Feeney 1970 911 T 1973 911 T Looking for engine 6103643 |
Just put them in and set them for 1.26
Bruce |
Just did it on a 204hp SC. No issues. Donīt forget you need screws now to tighten the cam gears.
I wasnīt on the dyno yet. But the feeling is much more power. (installed SSiīs, too). For those who did it, too. What CO on idel did you adjusted to be safe on high rpms? |
