-   -   89 Carrera engine hoses (http://forums.pelicanparts.com/911-engine-rebuilding-forum/822608-89-carrera-engine-hoses.html)
bcheney 07-27-2014 05:55 AM
Getting ready to plug in my rebuilt engine and need some reference pics to complete the engine breather hose routing. Anyone have some pics they can post? The Porshe PET doesnt really help to show all the correct connection points.
Here are the hoses I need help with...#25,26 and 28 in the diagram.
http://forums.pelicanparts.com/uploa...1406465706.jpg
Flat6pac 07-27-2014 09:57 AM
25 is a turbo piece only
Bruce
cmonref 07-27-2014 06:11 PM
#26 goes from the engine crankcase breather adjacent to the oil pressure idiot light sender.
#28 goes from the rubber 90 degree boot just above the throttle body.
Both of them connect to the oil tank fill tube. Either one is OK for either hose.
You have a third hose (not shown on your diagram) of a smaller diameter that goes from the lower port of the throttle body thru the smaller hole in the three-hose holder that bolts onto the air filter housing and also connects to the oil tank filler tube. At the throttle body, it provides warm air thru a temperature-opened port into the throttle body to provide deicing.
