Pressure Fed Tensioner Missing a part! Need a replacement.
One of the oil fed tensioners in my rebuilt project is missing the little pressure relief (control?) spring, ball and cap. Doesn't appear to be sold separately so unless I can "ignore" this I'm looking for another tensioner...
How critical is this part of the tensioner? Does it control the overall pressure in the piston? Anyone got a bad tensioner with these bits still good they want to sell? Or how about a used but good tensioner? Thanks all! |
Nope, you can not use it without the nipple, the oil will leak out and the tensioner will collapse. From there it can only end bad.
Read this thread with commentary from Walt Frike: http://forums.pelicanparts.com/porsche-911-technical-forum/574437-why-there-grease-nipple-my-tensioner.html |
I just replaced both of mine. I have two old extras. You can have one of them for parts, if that will help.
Afterburn 549 helped me out and just asked that I pay it forward, so this is pretty cool. Cheers, Mike
http://forums.pelicanparts.com/uploa...1375840822.jpg My home run would be to remove the nipple from the "failed" tensioner and install it on mine that is nipple-less. Not sure how to do that without bending the nipple. |
| All times are GMT -8. The time now is 04:18 AM. |
