Euro spec intake port
What's the 911 SC euro intake port spec? 39mm? Is this the only port on the heads that larger than US version or are exhaust and valves bigger also?
All valves are same size, 3.0, 3.2,and3.3
76/77 3.0, 78/79 US andROW and 80 to 83euro are all large port heads Bruce |
Large port heads...what's the measurement? Does that mean both the intake and exhaust ports or just the intake?
abit off center
The exhaust are both the same at 35mm the intakes are 39mm early and 34mm late SC
______________________ Craig G2Performance Twinplug, head work, case savers, rockers arms, etc. |
