-   -   Head stud washer thickness (http://forums.pelicanparts.com/911-engine-rebuilding-forum/825019-head-stud-washer-thickness.html)
DanCoffman 08-12-2014 03:00 AM
Hello all, I need a little advice. I am rebuilding a stock 2.7 engine. The head stud washers that I removed are about 2.5 mm thick. I have another set that are 3.0mm thick. The engine had suffered so many mistakes from someone's previous rebuild that I don't trust that the correct washers were installed. :eek: I have tried to find the correct thickness, but the information has so far eluded me. What is the correct thickness for the head stud washers?
Thanks!
Dan Coffman
Flat6pac 08-12-2014 04:59 AM
I miked several and 2.85 is the number
Bruce
tom1394racing 08-13-2014 08:14 AM
Dan
3 mm is the correct thickness
