-   -   question about the case casting... (http://forums.pelicanparts.com/911-engine-rebuilding-forum/825339-question-about-case-casting.html)
Kemo 08-14-2014 06:06 AM
I have my engine apart and I was cleaning and cleaning and noticed an interesting attribute of my SC's motor. I was a little nervous about what appeared to be a flaw in the casting. I didn't get a snapshot of it but I found a few pics on the forums of some open cases and added an arrow.
whats going on here?
http://forums.pelicanparts.com/uploa...1408021576.jpg
billjam 08-14-2014 06:27 AM
Don't panic. My 86 930 looked the same.
http://forums.pelicanparts.com/uploa...1408022839.jpg
E Sully 08-14-2014 08:01 AM
Internally there is no problem, but Porsche issued a technical bulletin to seal the outside of the case around the sleeve. I used a little JB Weld.
http://forums.pelicanparts.com/uploa...1408028425.jpg
stownsen914 08-14-2014 12:45 PM
It's a little hard to tell from the pics, but are these imperfections exposing the internal oil pipe to the open crankcase? I'd find such an imperfection hard to believe since it would seem to cause loss of oil pressure, not just a little seepage.
Flat6pac 08-14-2014 02:12 PM
Its just a possible drip but I clean, wire brush, and JBWeld inside of oil cooler area and out side under #6.
Bruce
KTL 08-14-2014 03:01 PM
Scott,
You are correct that this thin area of the casting exposes a section of the "J" pipe that goes from the pressure side of the oil pump to the engine case, up to the internal t-stat housing. There's no oil pressure loss because the pipe is continuous and well-sealed at the oil pump end.
The seepage is caused is from splash oiling inside the case (at that thin area) that then finds its way outside the case at the oil cooler recess as shown in the TSB.
