hooking up driver side hoses to engine
There are two hoses that I need help with.
One is from the fuel cannister on the passenger side of the engine bay. It is a cloth wrapped hose and comes across the to the driver side of the engine. The second hose is also on the driver side. I am not sure of its origin. My question, which hose goes to the line with a "T" near cylinder 2? Which hose goes closer to Cylinder 3 Here are the photos as I think they go, but wanted to make sure before I tightened the clamp. Thank you. http://forums.pelicanparts.com/uploa...1408934839.jpg http://forums.pelicanparts.com/uploa...1408934862.jpg |
The covered 13mm hose goes to the side of the air box, there is a nipple for the connection.
Burns off fumes from the canister on the right side fender wall Bruce |
As always, thank you.
As I understand, the hose from the charcal cannister (cloth wrapped) goes into the driver side of the airbox (done) and Hose 2 from the gas tank is the return hose and goes into the CIS plumbing. I am getting ready to fire her up after a "too" long rebuild.http://forums.pelicanparts.com/uploa...1409016218.jpg http://forums.pelicanparts.com/uploa...1409016260.jpg http://forums.pelicanparts.com/uploa...1409016317.jpg http://forums.pelicanparts.com/uploa...1409016413.jpg |
| All times are GMT -8. The time now is 10:36 AM. |
