camshafts
what is the speed of the camshafts to the crankshaft
Thanks |
Air Medal or two
In the old days they were call 1/2 shafts...because of 1/2 the speed
D troop 3/5 Air Cav,( Bastard CAV) and 162 Assult Helicopter Co- (Vultures) South of Saigon, U Minh Forest, Delta, and all parts in between |
1/2. You can see this when you time the cam or set lash.
Afterburn...sorry to differ...1/2 shafts are the separate drive shafts going from the transaxle to the rear wheels.
If you want to see a really complicated but wonderful rear drive system...look for De Dion system. I'm not sure if the Porshe one qualifies..but in my memory the De Dion system was for Track/Camber/Caster all at the same time. In the older race cars (Ferrari..Maserati...Fiat) you can see the travel of the wheel is held in the same plane throughout the entire travel...no tilt in at the top...etc. Bob
Bob Hutson |
Air Medal or two
Moot point anyway. Like said the cam is 1/2 the speed of crank on a "4 stroke" engine because of the exhaust stroke is in the middle. ( or every other stroke) There are two strokes in the world that use cam shafts and fire on every stroke http://en.wikipedia.org/wiki/Camshaft
D troop 3/5 Air Cav,( Bastard CAV) and 162 Assult Helicopter Co- (Vultures) South of Saigon, U Minh Forest, Delta, and all parts in between Last edited by afterburn 549; 09-06-2014 at 01:48 AM.. |
