-   -   Cam Sprocket Tool (P9191) (http://forums.pelicanparts.com/911-engine-rebuilding-forum/829933-cam-sprocket-tool-p9191.html)
bigel 09-15-2014 01:05 PM
I'm milling myself a P9191; have access to a machine shop and to any of the scrap metal bits. I found a nice piece of 304ss and milled it out to provide access for the socket to tighten the cam nut, but wasn't sure of the length of the three pins that interface the sprocket.
Anyone have access to the tool that would be willing to measure the length of the three pins?
I assume the need to be just long enough to engage the outer sprocket. The holes on the inner/outer sprocket don't necessarily match in the area corresponding to the three pins, right?
Thanks in advance.
DSPTurtle 09-15-2014 02:33 PM
Outer sprocket only. Don't forget to cut the notch so the left hand tensioner doesn't get in the way. If no one chimes in before Thursday I'll measure mine when I get home for you.
bigel 09-16-2014 12:42 PM
Thanks anyway DSP, but I've received the answer via cross-post.
DSPTurtle 09-16-2014 01:22 PM
So for posterity, what was the answer?
bigel 09-16-2014 02:07 PM
Sorry...the pins stick out 8.4mm and are 6mm in diameter.
DSPTurtle 09-16-2014 05:33 PM
Thanks for adding to the knowledgebase. Hopefully you'll post a pic of your handmade tool!
bigel 09-17-2014 05:34 AM
I'll be sure to post a photo once I finish it up.
