Rebuilding 3.2 / 930 Engine
First I will introduce myself and my project.
French Canadian ( I will make a lot a spelling and grammar mistake) I have no mechanical training but when I was at university I was doing my own mechanic to have more money to spend on brew. I'm the engineer type and see the logic in a engine. I have purchase a very very 1988 carrera shell everything except engine and transmission. I also purchase a Turbo engine with a transmission, I can say now that I was not a great idea, luckily the price was fair. My goal is to built (yes another one) 1973 rsr clone/replica not a identical one a better one :) The engine that a purchase came with a 915 transmission so I purchase a G50/00 for the strength and the ease of installation given the year of my car. I also purchase a Kep pressure plate with a sach clutch from what I see on Patrick Motorsport website it's rated at 550 lbs torque. Why all this information to built the engine accordingly I have decided to disemble the engine to find out what I had on my end and veryfied the condition of all the parts. Whith the price of parts and the power output this could be a recipe to desaster to my eyes. This is what I have Carrera 3.2 intake with original fuel rail and Porsche 944 turbo injectors Tial 46 wastegate Turbonetic HIFi 60-1 turbo 3.2 engine case http://forums.pelicanparts.com/uploa...1411482507.jpg I had my first surprise when I remove the valve cover http://forums.pelicanparts.com/uploa...1411482928.jpg Ti retainner, dammage valve cover, and broken spring and dammage by rubbing on the big aluminum block that sit on top of the engine head. I have 930 pistons and cylinder the look to be in great shape except for a crack cylinder http://forums.pelicanparts.com/uploa...1411483477.jpg The cylinder stud where ease to remove so easy that I remove some by hands I have carrera 3.2 engine heads I have a 930 crankshaft and 964 camshaft and 930 oil pump Now is the fun part. The goal is to built a engine that will last, a engine that will do 550lbs of torque to match my clutch and a engine that will pull at very low rpm (no turbo lag) Obviously I will like to reuse parts that I have but I'am also open to use other parts if they are much better I don't what to rebuilt the engine in 2 years. Let's discuss |
Nice project!
Nice project. You are designing the holy grail of motors. I look forward to your updates!
Pm me I am in Montreal
cant wait to see you get started
OK maybe I wasn't clear enough
I'm looking for advice on the built I pull the trigger on a GT3 crankshaft and now I'm debating piston and cylinders options. If I want the turbo to light up instantly I will like to go 8.5 C/R advice ? |
| All times are GMT -8. The time now is 02:17 AM. |
