-   -   EFI conversion (http://forums.pelicanparts.com/911-engine-rebuilding-forum/831125-efi-conversion.html)
magnum10 09-23-2014 06:49 PM
EFI conversion
Hello all. I am in the process of swapping my 930 parts to do an EFI conversion. My question is. Do I need my DME (I believe its what it is called) located under the dr seat?
I would appreciate any feedback on this.
Thank you..
GT2BH 09-23-2014 09:56 PM
I've seen people put the DME in different places - it really depends on what is more convenient - if you don't have back seats you can put it under the carpet. Make sure you measure your wiring though.
JJ 911SC 09-24-2014 02:10 AM
Originally Posted by magnum10 (Post 8275356)
... Do I need my DME (I believe its what it is called) located under the dr seat?
Thank you..
They are called ECU. You can mount pretty well anywhere in the cabin.
Since I had no functional back seat (due to the roll bar) I decided to build a break box for the 35+ signals and located there.
What systems are you going with?
http://forums.pelicanparts.com/uploa...1399510708.jpg
http://forums.pelicanparts.com/uploa...1399510741.jpg
magnum10 09-24-2014 05:31 AM
I purchased the unit from a fellow pelicaner nkowi. I am not very fermi liar with the components of it all. It is still up on the site though. Autotronic is the ecu the rest is Greek to me.
I am concerned that in the swap that I did I may have givin the dme (motronic) box that is under the seat when I may need it myself?? I am hoping that I do not need it with this new system??
turbobrat930 09-24-2014 05:36 AM
no, with the autotronic system, it replaces all the stock stuff....
magnum10 09-24-2014 05:46 AM
Correction.
The unit brand is autronic, with msd, gsf parts as well.
magnum10 09-24-2014 05:49 AM
That is great to hear.
Thank you for your time. I appreciate it.
I am fairly new to forums but this is a great site.
JJ 911SC 09-24-2014 07:42 AM
Good idea to keep your stock parts just in case...
http://forums.pelicanparts.com/porsche-911-used-parts-sale-wanted/829446-efi-conversion-930-sell-trade-stock-parts.html
safe 09-24-2014 10:49 AM
I mounted my ecu in the engine bay against the rear seat wall.
Bergo 09-25-2014 08:42 AM
Hi Magnum10,
small world, thanks for the turbo/exhaust/intake!
