RSR Engine Rebuild thinking
I picked up a '75 RSR Replica. The deal was right so I jumped on it.
It will replace my 924S Chumps car as my DE and then as my skills increase maybe PCA Club Racing. In the interim -- my 924S will satisfy my W2W desires. I realize I'm skiing over my tips here car wise, and moving into an opperating budget that I prefer to keep on the lower end of things. I've got about 6 months track time with a handful of DEs and a couple of stints wheel to wheel racing road courses. I have some Porsche engine experience, but this is my first air cooled, and I have a partner mechanic that knows his way around air cooled engines, but not a modified race engine. The RSR engine was in pieces and Im playing CSI with out the credentials. But lets assume all is good -- or at least I'll start with the components I have. Known -- 964 Case, 964 Crank, Clewett Pulley, Carilla Rods (haven't measured them yet) Mehle Cylinder Liners, 100mm Ross domed pistons, 100mm 993 Heads, look to be ported, twin plug, not sure of valve sizes yet 964 Cam Housing (I haven't pulled the cams yet) TWM Throttle Body and Fuel Injectors Motec M48 Also Known, I've got more car then my driving ability at the moment :-) What I've been told: (take all with a grain of salt) This was a 12.8:1 CR engine Failure might have been stretched or improperly torqued head studs leading to piston slap. Rumored 400+ HP Desires: Keep cost down - both short and long term. Keep things reliable Run in PCA DE's and maybe dabble in PCA Club Racing as my skills improve. My game plan at the moment is to just mic everything out -- make sure all mechanicals are good and then put it all back together replacing bearings, header/rod bolts, gaskets et al. Leaving the setup as is. Then either biting the bullet on AV gas, or detuning to run on pump gas. Then detune somewhat across the board to put HP in the mid 300's. How much HP will we lose making it safe to run on pump gas (I'll probably more than happy with that). As my skills increase and I can actually utilize the HP, I then can ratchet up the tuning to get more out of the engine/pay for AV gas as is desired. I've done a lot of reading about detonation and knock sensors. I don't need to play on that knife's edge. thoughts? thanks, Mike
2015 Panamera Hybrid, 2008 Cayenne Twin Turbo 2001 996 GT2 1999 Spec Boxster, 1996 993 Cabriolet 1992 964 Cabirolet, 1975 911 RSR Replica Race Car |
Mike,
Interesting project,...... ![]() A couple of thoughts,............. 1) Don't use Avgas. The octane formula isn't valid for race engines, its volatility and RVP isn't good for sea level operation and it has too much lead in it. Use race gas as runs MUCH better in every way. 2) Engine longevity depends on three things: compression ratio, operating RPM, and quality of assembly. There are a LOT of details involved when asking a motor to remain reliable if 8K RPM is desired. If the engine needs to last a few years, be conservative about CR and max RPM. Done right, you'll have a good time and learn something, too.
Steve Weiner Rennsport Systems Portland Oregon (503) 244-0990 porsche@rennsportsystems.com www.rennsportsystems.com |
Thank you, Steve.
yes quite a project indeed. Hope to be up and running by the fall. If I stay with the components as is -- I'm stuck with the CR. However, I do plan to limit the RPMs -- no reason to abuse the engine. 7-7.5k should be plenty. Hope to do the assembly correctly :-) At least commit to upgrading the head studs, replacing the rod bolts, and looking into racing rod bearings. looking forward to the learning -- hope to keep the tuition manageable :-) mike
Racer
Where is the engine designed to make power? If it is setup to rev to 8000 RPM and you limit it to 7000 RPM, you could be giving up a lot of power and driveability. You might need to a different cam setup....
Scott |
3.8 RSR cams are conservative (as far as race cams go) and make decent power from 4K to 8K. You can run them to 7200-7500 and once again, extend engine life between rebuilds. If you have something custom, I'd find out what they are. RSR head studs are already excellent, replace the SPS rod bolts (that what Carillo uses) when they are stretched beyond spec, and use a good aftermarket rod bearing such as JW Racing ones.
Did a quick search on JW Racing Bearings -- but it did not come up fruitful.
Have a pointer to a source. thank you, Mike
bearings
Thats Jerry Woods
Mike Bruns
The two most useless things to a driver are the braking distance behind you and nine-tenths of a second ago. |
Thanks..... for the next guy reading the thread...Smart Racing Bearings
http://www.smartracingproducts.com/catalog/engine.htm
I'm not trying to make huge HP. I'm trying to most economically get the car back on the track and keep it there. I realize that having an RSR replica and being economical might sound like an oxymoron, but it is the world that I am trying to live with. Quote:
this was a cobbled together engine design by SpeedWerks. A good engine, but a hybrid of many models and 3rd party parts. I plan to replace the rings, head bolts, rod bolts, and I like the idea of the JW bearings (although pricey). For components, I'm torn between just working with what I have vs the expense of replacing non-wear parts and risking non-compatability. still learning (and always will be), Mike
Recommend reading up on retuning for e85. That way compression ratio will not need to be altered and fuel is readily available and cheap. Might even pick up a couple hp.
Just need to make sure injectors and fuel pump are up to the task (approx 50% increase in flow). |
I like the idea Ollies930.
I just did some quick reading up. I'll have to see if the fuel system is up for it -- but I suspect it is. thanks, Mike
Circling back.
I had the CSI folks figure out what happened to the original engine (piston slap and melted heads) In the interim I rebuilt the top end of a street 3.6 and have been running that for a few years on 93. I'm looking at building up the original 3.8 -- but since the pistons are toast, I'm re-considering the E85 and looking to see what is the maximum CR I should consider. This will be a strictly track engine -- running at places like COTA and TWS (or its replacement) and maybe MSR-Cresson. Also the link to the Smart Racing Bearings is NLA -- so I'm on the search again for bearing solutions. thanks, mike
