Oil Seal Installation Tip
I ran across this little item in Hemmings and thought it worth passing on.
To facilitate installing a crankshaft (or other shaft) oil seal put it the freezer for awhile first. This will slightly reduce the diameter as well as harden the plastic/rubber on the outside of it making it easier to put in and get square. Sounded reasonable to me. |
Makes perfect sense to me.
yup, most seals
| All times are GMT -8. The time now is 06:03 PM. |
