-   -   Piston weight marking questions? (http://forums.pelicanparts.com/911-engine-rebuilding-forum/837226-piston-weight-marking-questions.html)
ertech 11-05-2014 05:23 AM
guys
i Need 1 piston/cyl .
1-can I use any stock 3.3 or does it have to be with the same weight markings?
My original Pistons are (--) the spare ones I have are (++)
2-Is the only difference weight?
3-If I remove a little material from the ++ and match to the -- should I be ok?
Erick
KTL 11-05-2014 09:13 AM
http://forums.pelicanparts.com/uploa...1415207482.jpg
http://forums.pelicanparts.com/uploa...1415207495.jpg
http://forums.pelicanparts.com/uploa...1415207512.jpg
http://forums.pelicanparts.com/uploa...1415207521.jpg
