What cams should I use in my 911 2.4 with 2.2S pistons?
The title says it all: What cams should I use in my 911 2.4 with 2.2S pistons?
Here is some facts: - 7R case (will have the oil bypass mod done) - 3.2 oil pump - 2.2S pistons - Twin plugged 2.7S heads (35/35 ports and new I46 E40 valves) - ARP rod bolts - Carrera tensioners - 40IDTP Webers (will most likely be replaced with 40IDA Webers) I now that the calculated compression will be somewhere around 10.4:1, but with twin plug, 98 octane fuel and the right cams this should be OK. I have considered the following cams: E, Solex, DC30, S, DC40 (Mod-S) or DC44. I want the impossible: huge low end torque ;) and screaming top end power somewhere around 7000-7500 revs :D It will be a streetcar that only occasionally sees a track – maybe once or twice a year. I want to be able to cruise around town without having to shift gears all the time, but I do like revs on the open roads as well – so I need a balanced compromise between low end torque and top end power. Greetings from Sweden SmileWavy Mikael |
I've heard good things about Mod Solex grind (DC40?). I would have gone that way had I put my hands on some good cores for a regrind. I decided to go with E to check my slide down the slippery slope.
DC30 = Mod-Solex DC40 = Mod-S SmileWavy |
cams?
I would go solex or softer. S on smaller motors is pretty puny down low then wait, wait for it then woooooooo. best
| All times are GMT -8. The time now is 03:30 AM. |
