Headstud washers?
Hello all,
I need to pick up a couple headstud washers locally. Is there anything unique about them or can I just match up the size? Thanks |
They're thicker than washers meant for general use, and flatter, as well. Get the right ones and be done with it.
The Cap'n |
They're also made of hardened forged steel.. not stamped out pot metal.
Short answer - you can't pick them up locally from a hardware store. A Porsche dealer (though nowadays they'd probably have to order), or a shop which works on Porsches (may have some used ones sitting around - used is just fine). If you happen to live next door to Maryland Metric or some specialty fastener place, maybe they'd have these, but I don't think they are in any way a standard washer. Others have noted features not found in normal washers. The thickness alone puts it in the special class.
I have freshly plated head stud washers.
PM me if interested. |
I was able to find them locally. Same size and thickness, $0.70 each
Just curious and I know it's insignificant but if you rattle them around together in a small paper bag or box or drop them on a stone hard surface so they ring?
If they do they're probably forged steel like the ones Porsche used. |
We have a bunch of used ones in stock, just down the highway from you....
Cheers |
Thanks Jeff, you were my next stop but I was able to find them in Chilliwack
| All times are GMT -8. The time now is 11:56 AM. |
