MFI Throttle Bodies Corroded
I'm in the process of rebuilding my 72 911 t targa with the 2.4L MFI. My throttle bodies are corroded. I've bead blasted them and they are much worse than I thought. See pictures.
http://forums.pelicanparts.com/uploa...1415420186.jpg http://forums.pelicanparts.com/uploa...1415420198.jpg http://forums.pelicanparts.com/uploa...1415420213.jpg http://forums.pelicanparts.com/uploa...1415420225.jpg http://forums.pelicanparts.com/uploa...1415420235.jpg I was planning on converting to EFI using the MFI throttle bodies, but I think these are past the point of no return. The plan was to boost the compression to 9.5:1 with the 964 cam profile with megasquirt EFI. Now that I've uncovered how bad my throttle bodies are, I believe my options are:
The engine will also have the following:
Any thoughts? Thanks, Kelly |
If your machinist friend is up to it...you could bore out and sleeve the throttle bores.
He could make you aluminum sleeves for the throttle shafts (bore out the old throttle shaft bore and then press in the new ones so that the new ones are larger diameter on the outside where the spring goes..and have the correct ID for the throttle shaft). These would need to be "stepped" to work properly. The end result...new throttle shaft bores...and a nice clean main bore of the correct size. He could also incorporate a space for an O-ring to prevent shaft leakage. Bob |
Rather than spend what could be an amazing amount of money reconditioning what you have, you might want to try to find some good repairable TBs from a boneyard, a private party, or some place like Competition Engineering in Lake Isabella, CA. (That last because I think he has some ...) If you're not in a rush, any good Porsche swap meet should have some for sale by one of the vendors.
The Cap'n |
There are a few options with throat diameter (38mm, 46mm, 52mm) using the GSXR throttle bodies that are separated so the 4th off of each pair can be removed. I'd want to keep the other three with the original spacing so the throttle linkage wouldn't need to be modified. Thoughts? |
I'm located in south Louisiana. Are there any swap meets within 250 miles of New Orleans? Thanks, Kelly |
There are several ideas on ITBs....do a search on here for them.
Using them will set your engine apart from stock...so...if you don't care about "original" looks...go for it. If..on the other hand ...you want it to look original...your choices are limited...rebuild what you have ..or like the Capn says...find good used ones. There are several companies that make parts for carbs that can cure some problems for you...like needing a slight overbore to clean up the surfacces. Holley carb company sells new throttle plates in many sizes...so if you have to overbore you might not need to sleeve back to original size. Good luck with the project. Bob |
| All times are GMT -8. The time now is 02:07 PM. |
