-   -   Oil Thermostat - Engine case orientation (http://forums.pelicanparts.com/911-engine-rebuilding-forum/839033-oil-thermostat-engine-case-orientation.html)
OS-Tech 11-17-2014 03:03 AM
HI all, new to forum and fairly new to Porsche cars. Currently I am restoring 85 Carrera 3.2 Targa. I am rebuilding the engine currently using Wayne book. I have a question with regard to the installation on the case mounted oil thermostat, the orientation to be precise. Does it matter which way around it is fitted?
Any help gratefully recieved as I have trawled photos and text, but to no avail.
Thanks :confused:
Flat6pac 11-17-2014 06:36 AM
It is bolted offset so it can only install properly.
Bruce
boyt911sc 11-17-2014 07:01 AM
One-way position........
Bruce
Like what Bruce said, it would fit correctly only at one position. Try to mount it the other way and you'll find the "off-set" orientation. I was in the same mental state (confused) when I first removed the engine thermostat using Haynes manual in the 90's and forgot to mark it.
Tony
OS-Tech 11-18-2014 04:09 AM
Thanks for the help, will try it later today and see how the offset changes.
Thanks, will update proguess
I
