Sealing IS stud
Working on an early case before re assembly. Any reason not to chamfer and o-ring the IS stud just like the through case bolts??
I would think if you were going to install an o-ring on the stud...it should be OK.
Be careful of the depth of the chamfer...and the thickness of the case at that point. And remember...in order to seal...you need a washer on top of the o-ring. Bob |
| All times are GMT -8. The time now is 01:47 AM. |
