-   -   How important are matching wrist pins to pistons? (http://forums.pelicanparts.com/911-engine-rebuilding-forum/840429-how-important-matching-wrist-pins-pistons.html)
ertech 11-26-2014 06:26 PM
Hi guys
How important are matching wrist pins to pistons on a 3.3 the machine shop might have mixed them up.
From your experience all wrist pins measure the same?
Erick
cgarr 11-26-2014 07:35 PM
They should all be the same but I like to match them by weight, mix and match pins and pistons to get each set close to the others.
Eagledriver 11-27-2014 09:49 PM
Not important at all.
tom1394racing 11-28-2014 12:49 PM
Wrist pins vary by less than 1 gram pin to pin
Pistons vary by several grams piston to piston within a set
ertech 11-28-2014 01:02 PM
Thanks guys
From your experience all pins are the same diameter?
Walt Fricke 11-28-2014 11:11 PM
That's what they are telling you. Same diameter. Which is why you can use their small weight differences (or shave off a bit of weight from one) to help fine tune piston overall balance.
