-   -   Quick SSI to 3.2 mounting hardware question (http://forums.pelicanparts.com/911-engine-rebuilding-forum/841262-quick-ssi-3-2-mounting-hardware-question.html)
gliding_serpent 12-03-2014 05:27 PM
SSI's each have a hole on the inner aspect of them where a bolt secures them to the front/middle part of the bottom of the engine.
This article ( Pelican Technical Article: Installing SSI Heat Exchangers on your 911 ) refers to these two bolts. "You’ll note that on both sides of the engine, towards the front on the bottom there is part of the engine that has a small bolt which has nothing attached to it. Take both bolts out. If you trial fit the heat exchanger, you’ll see that the bolt is there to help cinch down the heat exchanger to the engine."
Are these bolts in the 3.2? If they are not, what is the part number, and is drilling required?
thanks
Jeff Alton 12-04-2014 07:28 PM
They are not present, not required.
Cheers
gliding_serpent 12-04-2014 08:30 PM
Thank you
911pcars 12-06-2014 10:56 AM
Cheers
Agree, but I drilled and tapped the boss anyway. Do not make it a through-bolt. YMMV.
Sherwood
