-   -   Radiator shock insulation (http://forums.pelicanparts.com/911-engine-rebuilding-forum/841326-radiator-shock-insulation.html)
txhokie4life 12-04-2014 08:19 AM
Not sure if this fits in the engine rebuilding area or not -- but I figure there are a few fabricators online as well.
I need to build a custom frame for an aluminum radiator for our race car.
I'm trying to find a source for rubber insulation material.
Figure I would take some light sheet metal bend up a frame and line it with
rubber for shock absorption. I'm generally pretty resourceful -- but this
seems to have me stumped.
Love to find a source,
thanks,
Mike
RedCoupe 12-04-2014 10:24 AM
If you're talking about a water radiator for your 924 race car, I would post your question in the 924/944/968 forum. The guys who read this forum could help you mount your 911 oil cooler but wouldn't be much help on how to hang a radiator for a water pumper.
HawgRyder 12-04-2014 02:37 PM
Check out isolators from McMaster-Carr.
They are the things that have a stud on each end with rubber in between.
They come in many sizes and mass holding capacity.
The resiliance of the rubber (stiffness) is also a factor.
We used them on racing buggies for all sorts of vibration prone to damage things.
Bob
911pcars 12-07-2014 10:17 PM
If you have the time, perhaps a visit to your local Pik-a-Parts wrecking yard. Pull a few radiators and see what different vehicles use and observe their methods of supporting the radiator. Rubber radiator mounts from a large displacement engine should be beefy enough; maybe less costly than adapting an industrial product. Resiliance would be important.
Sherwood
