-   -   Lighter 3,0 valves -maybe Ti (http://forums.pelicanparts.com/911-engine-rebuilding-forum/842458-lighter-3-0-valves-maybe-ti.html)
MaRu 12-12-2014 06:45 AM
Hello guys,
i am looking for some lighter Valves for a hot rod 3,0 engine. At this point I am not sure if standart size (49/41,5) or bigger. I talked to del west. They can make them individual but donīt have them ready. I am sure I have read about people selling them here in the past. But I cannot remember who this were. Any ideas who is selling Ti valves with 9mm valve steam?
many thanks!
KTL 12-12-2014 09:29 AM
Check with Henry Schmidt at Supertec Performance
Steve@Rennsport 12-12-2014 04:33 PM
You'll need beryllium-copper seats for them to last and those are not cheap to install.
HawgRyder 12-12-2014 07:58 PM
If you do go with the Beryllium-Copper seats...please resist the urge to run your finger around them to see how smooth they are.
Beryllium is poisonous!!!
If it gets into your blood...you are not going to like the result.
A lot of military electronic equipment has thin springy fingers of the stuff on panels to make sure the panel is "sealed" electronically (RF leakage).
We were cautioned very often about getting cut on this stuff.
Bob
Steve@Rennsport 12-12-2014 10:47 PM
Bob is spot-on; Berylllium is VERY toxic (lethal) and we wear protective clothing & respirators when machining the seats during installation.
All this adds to the completed costs of using Ti valves.
chris_seven 12-13-2014 12:14 AM
Beryllium Poisoning is quite tricky.
Ingestion of Beryllium is not particularly dangerous and the metal is not poisonous in the traditional sense so it is relatively safe to touch and handle and Copper/Beryllium alloys have been used to make hand tools for use in hazardous areas for many years as the alloys develop good strength but are non-sparking.
The alloy is also used for the manufacture of a significant number of springs.
Beryllium containing alloys are used commonly in the Oil, Nuclear and Aerospace industries.
Where Beryllium is an issue is when fine particles of both the metal and its oxide are inhaled.
Once in the lungs it can be transported by the blood and can have other affects on the liver and other organs but this is uncommon. Its main danger is to the lungs and it can cause severe pneumonia like symptoms and is considered carcinogenic.
Machining Berylium does need some care and the use of high flow rates of coolant and I would always wear they type of respirators used in paint shops but it is not really dangerous to the touch.
http://materion.com/~/media/Files/PDFs/Corporate/FAQs/FAQ108SkinContactandCopperBeryllium.pdf
safe 12-13-2014 01:11 AM
Isn't it better to go with 8 mm stem valves of a more modern design and common alloy such as stainless?
Those are lighter and valve guide replacement are usually needed anyway.
MaRu 12-13-2014 04:55 AM
Thank you all for your answers! I will send Henry an email. Magnus, are there 8mm Valves that are plug and play? -or do they need to be manufactured?
safe 12-13-2014 06:19 AM
Not sure. A friend fitted some non porsche valves from Manley I think. They were slightly larger so the seat had to be cut.
MaRu 12-15-2014 01:08 AM
Thank you very much!
304065 12-16-2014 10:20 AM
toyota valves
